1 members (216wny),
70
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 26 Member | | Member Joined: Jan 2003 Posts: 26 | 52' with a 235. Rochester Carb I thought Ken's post from 12-1 (hesitation ...) was just what I was lookin for, but nope. Drove home the other night and thought I was running out of gas (1/2 tank). For some reason I pulled out the choke, it came back but with higher RPMs. Pushed the choke in and it died. Got any thoughts? Thanks ahead of time, jeff | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Closing off the top of the carb (choke) does increase vacuum. I would check for vacuum leaks or fuel delivery problems, clogged fuel filter, fuel pump etc.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | Sounds like the main jet/orifice may be partially plugged. Closing the choke helps "suck" more fuel through the main circuit (it is actually atmospheric pressure that pushes the fuel to an area of lower pressure). | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Since it's a leakmeister Rochester, check the throttle body shaft for wear, too. Major source for vacuum leaks.
Fred 52 3600 69 C-10
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Have you checked the heat riser operation? | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | All good points and I would like to add ,,, Look for vacuum leaks at the intake to head and around the base of the carb.
| | | | | Joined: Jan 2003 Posts: 26 Member | | Member Joined: Jan 2003 Posts: 26 | Thanks Guys, As usual, the responses are "always" quality. And, in checking all of the above, I've ordered a rebuild kit from NAPA. Can't hurt. I should have this solved over the weekend. Thank you all ahead of time, jeff P.S. For all you Southern Californers, don't forget Pomona this Sunday. An remember to pack your flashlight-still dark at 5;30am. | | |
