2 members (Ponchogl, Hush), 67 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#654731 06/14/2010 8:04 PM
Had a gas cap gasket failure on the 05 Grand Prix and it of course set two codes, one for the cap and the other SES light. Even after replacing the cap, you still have codes so, I picked up the Innova 3100 OBD2 Diagnostic Tool. It took 15 seconds for this little wonder to clear the codes and I have been good to go for over two weeks now. Thought I would share this info. for those of you have OBD1 OR OBD2 daily drivers. At around $100.00 it beats the dealer and most independents cost wise.
http://www.canobd2.com
Hank
1951 restoration on website
http://www.hanklong.com
Often Adnavce Auto, Autozone, and the like will scan and if you ask nicely clear codes for free. Which is a good option if you don't regurlarly have problems and don't want or need to invest in the tool.
Canadians can get one here for $40.00 for the next 12 days:
http://www.princessauto.com/tools/auto-repair/diagnostic-tools/8312621-obdii-code-reader
You Tube
Grigg, that's if you trust them to handle that, many of their employees are suspect at best?
Curt, there are a lot of cheap options and you get what you pay for with these things, this has support and c.d. with code reference for those not in the device. I want the best bang for my buck, just sharing this for those that might need it. I remember seeing a code reader only for $20.00 at one point, but they are crap and that is not what I was talking about here.
Not saying the autoparts store is always the best option, but when you already know the problem and solution (like left gas cap off) and you just want it cleared it's an easy and cheap way to go about it.
For those with Volkswagens this is the best tool available for this sort of stuff.
http://www.ross-tech.com/
Can also log Data while running/driving, for example boost pressure and requested boost. It will check timing, and countless other things, it's way more useful than I know what to do with yet.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Check out obdcom.com (on sale $87.00) Just bought one of these. Gives lots of information, and clears codes. Example: hooked it up to my wifes car, 03 Grand Prix SE. It showed that it did 0 to 60 MPH in 9.8 seconds. Kinda KOOL I think.
Brian
Brian
1955.2 3100 Truck
I agree Brian, they are trick little devices to have around. For around $100 what the heck?
Moderated by  MNSmith
