7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible), 123 guests, and 1 robot.
Topics128,095
Posts1,056,072
Members48,433
#653825 06/10/2010 8:09 PM
Hello, I need the point gap for the distrubutor on a 1946 216 engine. I did a search but couldn't find the spec. Thanks, Al.
Drew
3B Offline
Hy DrewP, .019 new, .016 used, hope that helps.
Hello Radiowaves88, I recomend getting a Pertronix Ignitor and ditching your points. I installed one about two months ago and the truck never ran so good. I also used the Pertronix Flamethrower coil. You can call Pertronix and give the tech your Distributor numbers from the inside plate and they can tell you wich part is needed.
.016? isn't that about the same thickness as a matchbook cover? When "proper tools" were unavailable it's what I used for settin points on old VW's! grin
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Here is a link for you to start with. The point gap should be around .22
http://www.secondchancegarage.com/public/359.cfm
