| | | Forums66 Topics128,094 Posts1,056,157 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 17 New Guy | | New Guy Joined: Nov 2006 Posts: 17 | Hello, I need the point gap for the distrubutor on a 1946 216 engine. I did a search but couldn't find the spec. Thanks, Al. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy DrewP, .019 new, .016 used, hope that helps. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hello Radiowaves88, I recomend getting a Pertronix Ignitor and ditching your points. I installed one about two months ago and the truck never ran so good. I also used the Pertronix Flamethrower coil. You can call Pertronix and give the tech your Distributor numbers from the inside plate and they can tell you wich part is needed. | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | .016? isn't that about the same thickness as a matchbook cover? When "proper tools" were unavailable it's what I used for settin points on old VW's!  1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
