8 members (SNOYL, Southerntruck, Phoneman, wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag),
155
Mod | | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | Will 3/4 ton GMC AD rear fenders fit my '52 burb? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 |
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | Will a 1953 Chevy panel 3800 fender work? | | | | | Joined: Nov 2001 Posts: 1,522 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,522 | I thought they were all the same............... | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | The profile of the fenders is the same but they bolt on differently. | | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | OK, so they'll work I'll just have to adjust the bolt holes?
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | OK, so they'll work I'll just have to adjust the bolt holes? NOPE.......... Burb/Panel trucks the lips are straight where it bolts on, as the truck fender has about a 90* bend in it where it bolts on. Now if you are handy you may be able to modify the truck fender where the lip is & make it flat....joe | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Will 3/4 ton GMC AD rear fenders fit my '52 burb? Will a 1953 Chevy panel 3800 fender work? A 1953 GM-truck 1-ton panel rear-fender will work fine on the 1/2 ton 1952 Suburban. (Any 47-55 A-D/ND panel-body rear-fender will interchange; however, ones that had stainless trim would have trim-holes in them)
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Will 3/4 ton GMC AD rear fenders fit my '52 burb? Will a 1953 Chevy panel 3800 fender work? A 1953 GM-truck panel rear-fender will work fine on the 1/2 ton 1952 Suburban. I must have missed the part about the 3800 panel fender. But what Tim has said is true. The GMC/Chevy 1/2ton & 1 ton Panel/Burb fenders are the same | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I think I missed it too. I was trying to say that pickup fenders don't bolt onto panels or burbs. | | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | there is no 1 ton Suburbans in real life at that time. only Panel trucks go up to the 1 ton. Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Panel & Canopy Express came in 1/2 ton and 1 ton (at least for 47-55).
| | | | | Joined: Jul 2008 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 13 | Hello,
I am in need of a pair of fenders for a 3/4 ton 53 chevy. If you aren't going to use them could you pass along the contact information to me?
thanks
Some people say I suffer from insanity, in reality, I enjoy every minute of it!
