1 members (KEVINSKI),
63
Mod | | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | is there a trick to it or a special tool to expand the rings? i just bent a number of the old ones taking them off, id like to put the new ones on with out bending them.
66' Chevy C-30 Rat
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Which rings did you bend? I assume you're referring to the steel rails on the oil ring assemblies, as trying to bend a cast ring will result in it breaking- - - -they're cast, and very brittle. Cast compression rings need to be stretched to install them, never twisted. There's a ring installation tool that does that, but be careful not to stretch the rings more than necessary. They can break from over-stretching, too. The oil ring rails need to have one end started into the ring groove, and carefully spiralled onto the piston - - - -not stretched at all. Be sure the corrugated expander between the rails has the ends butted together, not overlapped. Jerry
