5 members (1955 1 Series, 49nut, rfs56trk, Eisenholtz, tclederman), 88 guests, and 0 robots.
Topics128,046
Posts1,055,618
#654480 06/13/2010 5:53 PM
I posted a topic about locating my vin on my truck. I did some searching in the forums and still have a question if anyone can help. My title number is K3989978. It is a chevy 1/2 ton pickup. I was wondering what this number pertains to since I can't find it on the truck. The title is not in my name and am wondering how to match this title...is there another place I should be looking...what do the numbers represent...does not sound like a normal ID number you find on the ID plate. Any thoughts would be appreciated.
It might be an engine serial number (that code was often used for registration/title). It looks like you know that the vehicle/model ID for a 1934 1/2 ton commercial vehicle has a DB in the code.
the 1934-1935 and 1936 high cab had a data plate on the fire wall. This and or the engine number was used for the vin. Back then there was no vin numbers.
The body tag or engine number is the only set of numbers on a truck unless a state installed and aftermarket number.
Poets Seat Auto
Appraisals, Parts, Service
Past: General Motor's Master Technician
Member: Northeast Chevy/GMC Truck Club
Phone Number: 413.774.5856
Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
That number should be above the fuel pump on a flat spot of the block--stamped --Ithink. At least most of it.
A previous discussion on 34 motors yielded this website.
http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/1934motors.html
Your number is an engine serial number. The number falls in the Dec 1933 - Jan 1934
production numbers.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
