6 members (46 Texaco, 55shaker, J Lucas, PAUL Berardi, Otto Skorzeny, 1 invisible), 70 guests, and 4 robots.
Topics128,083
Posts1,056,327
Members48,442
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
I found this over on HAMB, GMC BUBBA did a post on how to change an early GM point dist to HEI, thought some of you may like to use this Tech Tip...Joe
CLICK......................
Here's GMC BUBBA's Tech-Tip for an earlier 6-cylinder points-distributor to 12v HEI conversion.
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
thumbs_up I thought I had seen a post on someone doing one b4..Joe
Great info!
Grigg
I don't get the jargon; He specs a reluctor after mentioning Chrysler and GM so what reluctor does he reccomend?
1999 GMC Yukon
1957 GMC 100 Panel
He's using a MOPAR reluctor and pickup coil adapted to the GM 6-cylinder distributor cam. Good-looking installation, but there's a reason the GM HEI cap is so big. There's a danger of flashover from one cap terminal to another, especially if an open-circuited plug wire is present, or a wire falls off a plug. Don't run a wide plug gap if you choose to use the original cap and rotor with HEI system coil voltage.
Bring this back to the top, as it seems to be a great idea and several folks have asked about it recently.
In fact I've got one and all the parts here in the shop, just need the time to try the conversion. Will take pictures and comment when I get to it.
Pictures and info from the original poster
http://www.lindertech.com/bhrs/gm_6_dist_elec_conv.htm
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
1 Offline
here is a tech article i did over on the HAMB site to drop a 250 hei into a 235, cheap and easy! http://www.jalopyjournal.com/forum/showthread.php?t=189074
On the 250 HEI Swap, anyone know if this would work for a 216?
Petronix makes an electronic conversion kit for the 235 dist. No need to find a 250 dist at junkyard.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Yep, but the GM HEI actually works!
1 Offline
pretty easy conversion.
yes it will work the same. philip
What alternator are you guys using for this , I want my set-up to be as sweet and simple as possible. Is there a post that shows a step by step conversion from a 12v gen. to an alt with an hei. thanks guys
ps, 59 apache 235
left feild-this is a site i found when i was re wiring my truck. it also has alot of helpfull info like the theory behind generators/alternator, the diffrences between those and internal vs. external regulated lots of good stuff! he uses buick wiring diagrams, but they can at least give you a good understanding of the wiring involved in a conversion and how simple it can be to do it yourself. http://www.rowand.net/shop/tech/AlternatorConversions.htm hope it helps
66' Chevy C-30 Rat
Thanks Brian, I'll give it a read.
