5 members (treegrower, Bill Hanlon, Hotrod Lincoln, HandyAndy, FAST55), 186 guests, and 7 robots.
Topics128,077
Posts1,056,015
Members48,433
#65351 09/06/2006 3:09 PM
Junior Member
Junior Member
I've purchased new tapered wheel bearings for my '51 1/2 ton Chevy. I'm not certain how tight to torque the nut on. I read a post here earlier that seemed to say it should be less tight than factory specs. Should I follow the factory recommendations for the original wheel bearings ?
John Morris
washington, Vt
#65352 09/06/2006 6:01 PM
Just tighten the nut snug and spin the wheel. When the wheel stops, back the nut off. Turn the nut back on "by hand" until it is as tight as you can get it. Back it off just until you can get the cotter pin in.
#65353 09/06/2006 8:20 PM
MtManVt,
Do you still have the boxes the bearings came in...do you have any bearing numbers you could share with the forum...how about a seal number?
Stuart
#65354 09/06/2006 9:06 PM
Or better yet,,,where did you buy them?
#65355 09/07/2006 1:49 PM
Junior Member
Junior Member
I bought the bearings from a company that used to be Chevy Duty. I think their called Classic parts or something now. I still have the boxes. I'll check for numbers when I get home tonight. Thanks.
#65356 09/12/2006 3:44 PM
According to the manual, tighten nut to 33 ft*lbs, then back off 1/12 to 1/6 turn until one of the slots lines up with the holes.
Simplicity leads to reliability.
#65357 09/12/2006 5:02 PM
Polecat, those directions are for the original ball type bearings, which require pre-loading for correct adjustment. Tapered bearings are'nt as sensitive to this, andBuilder's reccomendation is correct for the adjustment.
Bill Burmeister
#65358 09/12/2006 5:37 PM
I too would like the bearing and seal part numbers and manufacturer's names.
I imagine they are available from NAPA or elsewhere cheaper than the vendors have them but without the part numbers the FLAPS can't figure out what bearings or seals to use.
So, if you would post that that would be a great help for all of us!
#65359 09/12/2006 10:37 PM
You can get your Federal Mogul/ BCA bearing numbers, seals Here
or Here
-Tom
1950 Chevy 3100 w/ 1956 235
#65360 09/13/2006 1:46 PM
Junior Member
Junior Member
Sorry guys I lost the boxes and don't have the numbers.
