9 members (FAST55, Shaffer's1950, John Dlugos, Ponchogl, F100Ranger, Otto Skorzeny, Gdads51, TexasJim50, 1 invisible),
73
Mod | | | Forums66 Topics128,131 Posts1,056,372 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 64 | I am having a real problem removing the distributor from the block, The clamp is off,the bolt to the block is off and I have "blasted "it for days. It will not move.Any suggestions on the next step or have I missed something? Thanks in advance, Doug | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Does the motor turn? With everything that holds it in place spinnng the motor might break it loose.
Of course that means you'll be working a little harder to get it back in the right place.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 64 | Yes , the engine was actually fired up and taken off a trailer when I bought in March. I can also turn it over by hand, the head and pan are off, I am just trying to "clean " it up. Maybe I should stop while I am ahead? Thanks for comments, Doug | | | | | Joined: Feb 2004 Posts: 29,813 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,813 | Will the distributor housing turn? Grab the housing just above the vacuum advance with a big pair of channellocks, and turn it back and forth. That will help work the penetrating oil down between the housing and the block. Eventually, the distributor will start to move upward, as well as side to side. Jerry
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | like jerry said does it turn? if it does and if your 228 is set up like it is on my 40 then on the left hand side of the dist. is a bolt with a spring under it. it will not come out unless you remove the bolt. it is what lets the vac. advance work. | | | | | Joined: Mar 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 64 | Success , I got it with big channel locks, thanks. Just for you info on the 41 the bolt to the left of the distributor holds a plate to the block and the little spring is attached to that plate on the right side of the distributor. A slight change from the 40 to 41. thanks again. doug | | |
