4 members (Wally / Montana, Bill Hanlon, TexasJim50, jkreiner), 49 guests, and 0 robots.
Topics128,074
Posts1,055,914
Members48,429
#653086 06/07/2010 10:25 PM
With a lot of reading through these forums and a couple of others, I gained the courage to get this truck back on the road. It is a long way from being finished but it has had its cam break in and it will soon be ready for a test drive. My son shot this video. You will notice it is sporting one of Tom's cast iron split header. smile
gtbrain #653155 06/08/2010 3:36 AM
Hey, that is cool. I've got my 65's bed looking the same way. the video is great I need to get some pics also. have fun Brett
longboarder #653287 06/08/2010 5:44 PM
what master cylinder have you used
terry munday #653604 06/09/2010 9:56 PM
i used the master cylinder out of an 83 half ton. I also used the complete front crossmember from that same truck. I am using drop spindles and springs.
gtbrain #653922 06/11/2010 3:35 AM
didyou change rearend or axles? also steering box?
terry munday #653967 06/11/2010 12:37 PM
Looks and sounds great.
1962 C-10 Chevy
More pix on Photobucket
ADHD and luvin' it
terry munday #654554 06/14/2010 1:49 AM
yes the rearend is from an 83 1/2 ton. I also used the complete front crossmember from the 83. It was an easy bolt in with just drilling out a couple new holes. And yes the steering box came from the 83 donor too. I added drop spindles and springs up front with lowering springs for the rear.
gtbrain #654561 06/14/2010 2:26 AM
thank you for the info. also did you have any trouble attaching the master cylinder?
terry munday #654955 06/15/2010 5:27 PM
No trouble at all. It bolted right up. I did have to modify the push rod some.
gtbrain #659577 07/04/2010 4:37 AM
Here is mine.
