Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Sedgewick, Charles in CA, crenwelge, UtahYork, TexasFarmTruck, Mike1933), 161 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#65317 09/05/2006 4:41 AM
My rear drums had residue of a paper element around the 6 lug nuts. No evidence of any paper residue on the front. Are these needed when I'm re-doing the brakes? I believe they're called "paper gaskets"?
1951 Chevy 3100 w/235
#65318 09/05/2006 10:03 PM
Riding in the Passing Lane
No as long as you clean it all off.
1972 Chevy c10 Cheyenne Super
#65319 09/05/2006 10:10 PM
Never seen a drum with a paper gasket on it. Huuuuuummm?! I would have to say clean that stuff off.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#65320 09/06/2006 7:59 PM
I've seen that. Mine had that on it too. I think it may have been there for rust prevention between the hub and drum, but it is't needed for brake operation. Just clean it all off and maybe a light coat of anti-seize to prevent rust.
Bill Burmeister
#65321 09/07/2006 12:24 AM
Longbox55 is right, and my 51 had the gaskets also. Like he says, just apply a small amount of anti-sieze where the gasket was and you'll be OK.
#65322 09/07/2006 1:58 AM
The gaskets were commonly used, perhaps to keep the rear wheels from rusting to the hubs. The gaskets are available from Chevs of the 40s and Obsolete Chevrolet Parts Company. The gaskets are not mentioned in the Shop Manual I just looked at (1954 Canadian Chevrolet & GMC Trucks)
#65323 09/07/2006 2:45 AM
Good info guys.
Mike
#65324 09/08/2006 4:43 AM
1 Offline
Mike,
I took some photos of my 52 burb's rear brakes and tried to get you some good photos of the parts you're missing,
first photo: "spreader bar" below wheel cylinder
2nd photo: parking brake cable attaches to the "parking brake lever"
last photo: shows the "spreader bar", Parking brake lever and the brake shoes. I put it on top of the shoes for a better photo for you.
I have a pair of Parking brake levers I will sell you and I only have 1 spreader bar I'd throw it in also. let me know.
http://picasaweb.google.com/corynolen/52BurbBrakes
1954 Chevy 3100
1952 Chevy Suburban
#65325 09/12/2006 9:29 PM
Pictures are great. I was able to find two struts, levers, and mounting hardware from a guy in Arizona. I'll be using these pictures to help with the rebuild.
MIke
