2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#652900 06/07/2010 3:06 AM
I bought a 1959 32 series truck and the frame is different than any others I have seen. the front engine cross member is different and the shape of the frame is a little different around where the steering box bolts up. Here is a link to a picture http://rides.webshots.com/photo/2860715880102329435wCaAuu and http://rides.webshots.com/photo/2017662070102329435WpeVEn
What engine would have bolted in at the front center of the cross member. I have looked at several 55-59 frames and have not found anything like this.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
H Online: Content
Some of the V-8 trucks had a horseshoe-shaped front mount that bolted into the center of the crossmember and used the same mounting holes as the pre-58 passenger cars on both sides of the harmonic balancer. The frame modification was probably for exhaust manifold clearance on the V-8 engine.
Looks like a mount for a 235.
The area near the steering box looks to be a factory stamping. no hammer marks and it is perfectly uniform. all the frames I have seen have the two holes where the 6 cylinder mounts would go through the cross member. I did see a 348 one time that had a center front mounting bracket but it was not in anything so I do not know what it was out of.
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
GMC perhaps?
Bill Burmeister
Thanks Bill, I bet it is a gmc. The bed that is on the truck has a GMC tailgate. Is this going to cause me any problems other than having to fab up my own motor mount? I plan on transfering my NAPCO 4x4 parts over from my other chevy chassis. The NAPCO is a short bed and the frame is really thin in spots from rust. Another reason is I want to use the fleetside long bed that I have.
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
