| | | Forums66 Topics128,062 Posts1,055,851 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | I bought a 1959 32 series truck and the frame is different than any others I have seen. the front engine cross member is different and the shape of the frame is a little different around where the steering box bolts up. Here is a link to a picture http://rides.webshots.com/photo/2860715880102329435wCaAuu and http://rides.webshots.com/photo/2017662070102329435WpeVEnWhat engine would have bolted in at the front center of the cross member. I have looked at several 55-59 frames and have not found anything like this. | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Some of the V-8 trucks had a horseshoe-shaped front mount that bolted into the center of the crossmember and used the same mounting holes as the pre-58 passenger cars on both sides of the harmonic balancer. The frame modification was probably for exhaust manifold clearance on the V-8 engine. Jerry
| | | | | Joined: Jan 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 83 | Looks like a mount for a 235. | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | The area near the steering box looks to be a factory stamping. no hammer marks and it is perfectly uniform. all the frames I have seen have the two holes where the 6 cylinder mounts would go through the cross member. I did see a 348 one time that had a center front mounting bracket but it was not in anything so I do not know what it was out of. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Thanks Bill, I bet it is a gmc. The bed that is on the truck has a GMC tailgate. Is this going to cause me any problems other than having to fab up my own motor mount? I plan on transfering my NAPCO 4x4 parts over from my other chevy chassis. The NAPCO is a short bed and the frame is really thin in spots from rust. Another reason is I want to use the fleetside long bed that I have. | | |
