5 members (55shaker, Phak1, 49fastback, Biermann, Jaison), 106 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
#652977 06/07/2010 1:11 PM
I found a prefab. stainless, dual exhaust setup for Fenton headers. The description said that it only fit 1/2 ton trucks, and not 3/4 ton. Is there a difference in the engine bay, or is it the length of the truck that is different between the two?
Wes
http://www.streetrodhq.com/detail/2...M_COMPLETE_POLISHED_STAINLESS_STEEL.html
47-55 Chevrolet truck?
the length is the difference (with respect to the exhaust setup)
Thanks. So, I could install the pipes from the Fentons, with the muffler, and then would have to adjust or lengthen the pipes from the muffler to the tailpipes.
wes,
Someone with a short-bed and long-bed will have to respond. What you will have to lengthen depends on where the 3/4 ton axle is located, compared to the distance to the bumper and the distance to the muffler (assuming the short-bed and long-bed mufflers go in the same location).
