2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#65279 09/03/2006 6:47 PM
Junior Member
Junior Member
i've been selling bits and pieces off a '64 gmc i bought for the bed & frame. someone wants the tran & bellhousing but i'm having problems getting them seperated from the 305v6.
i've removed the starter and top four bellhousing bolts but i can't seem to be able to break it loose. i haven't completed my shop manual collection yet so i don't have anything on the v6 assembly so i'm asking here; what am i missing?
the engine/tran has been removed from the truck and is sitting on the ground if that makes a difference.
thanks
bill graham
If it is anything like the early Chevies, there are two bolts behind the flywheel. You would need to remove the transmission, then the clutch and flywheel to get to them if that is the case. It will be easier to handle the transmission and bellhousing separately anyway.
Junior Member
Junior Member
yep, wasn't expecting that.
had to pull an inspection type plate, then unbolt the tran from the bellhousing. pull the tran, pull the fork , pressure plate, clutch, and flywheel. then four more bolts for the bellhousing.
man all that stuff is heavy duty.....and heavy.
thanks
bill graham
