| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65276 09/03/2006 4:18 PM | Joined: Jan 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 23 | Found me a distributor in the pile 1112304, nice safe choice fits most 235. The grease cup is empty. So what do you use? Cup grease? Take out the cup and put a zerc in there? How many actually use the cup anyway. I never do, but I know that shaft needs grease of some kind. What's the best way to go? | | |
#65277 09/03/2006 5:50 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a thought.....you didn't mention what engine you were going to use 1112304 in. You might want to verify that the drive gear matches up with your cam....pre-54's were forged cams, 54's and newer were cast cams. www.secondchancegarage.com/public/373.cfm has an engine spec page that identifies various components. I browsed their info and couldn't come up with your number.....although 1112403 is a common later-model distributor that fits most applications from 54-60. You might want to check it out. Can't help you with the specific grease...I use a high temp.general-purpose and very sparingly. Hope this helps. | | |
#65278 09/03/2006 9:39 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The manual says to use chassis lube. How it works is that you fill the cup, then turn the knob 1/2 turn every 1000 miles.
Bill Burmeister | | |
