3 members (GMCJammer51, Woodcmiami, Pre '68 Dave), 54 guests, and 1 robot.
Topics128,050
Posts1,055,753
#651833 06/02/2010 9:14 PM
does the caliper mount on the front of the disk or on the backside towards the doors,,, and it looks like i have to drill out the bottom mounting hole,, is this normal?/
Most important is that the bleed screw end up at the top and that nothing hit anything when steering.
Having to drill the lower hole is a sign you have an early axle and not unusual.
I bought my kit from someone else and the instructions were pretty clear about that possible need while vague on other things. But then on mine I don't think drilling out the hole was required.
It mounts on the rear facing side (not forward) of the rotor. The Bleed screw MUST be on top.
I'm suggesting calling ECI for any guidance you may require. They are very knowledgable and friendly. This is the advice I'm taking when I do mine.....in a couple of weeks.
Good Luck
thanks for the help,, its all mounted, I had an early style axle with 1/2 bolts on the bottom of the steering linkage, had to drill out the bottom hole and the spacer to fit the 1/2 inch bolt, trimmed a casting spot on the caliper and modify the wheel stops.. it looks good so far..
