| | | Forums66 Topics128,154 Posts1,056,861 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Just curious, if I would have to go to a 19.5 inch rim the tires are just over 32" tall. How tall are the 8.25 x20 originals? Mine are not home right now to measure.
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 54 | Most new 8.25x20's are around 38.5" tall. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The tubeless equivalent to 8.25x20 is about a 9R22.5
Grigg | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Grigg, I was looking at my options on getting wheels for my truck. Your tech tip article on big bolt tires led me to look at modern 19.5 rims, but you thought they might look small on a two ton. I was talking to the guys at Les Schwab and there is a profile that could be as tall as 41 inches on a 19.5 rim. Do you know how wide a tire one could get away with for the duals on the rear? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes there are larger 19.5" tires... But what will your wheel width be? If you use standard GM 10 lug 19.5" wheels as far as I know they only come 6" wide, which then pretty much limits you to a tire as large as a 8R19.5.
I suppose having custom wider rims made is an option. I would try to get a good idea how it would all look and fit and what it would cost before taking that path.
I still think original 20" wheels and tires are the best option for most folks who won't be taking long road trips and regularly hauling stuff. Then for those who want a more modern truck the 22.5" wheels compliment the other changes (axles, gears, brakes, more power).
The 19.5" wheels if they fit over the drums could be a cheap (used tires and wheels) way to get a truck on the road, may run slower and look funny, but driving is better than sitting on blocks in the driveway.
Grigg | | |
