| | | Forums66 Topics128,095 Posts1,056,078 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 22 New Guy | | New Guy Joined: Aug 2009 Posts: 22 | Did half ton GMCs have 2 different front springs in 66 ? I am wanting to lower the front. I was told by a friend that has a 66 Chevy that if I had the correct springs I could cut 1 complete coil off the spring and not affect the ride or steering. I have ridden in this truck and it did ride great. I had no idea they were cut. Thanks n Advance | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Cutting springs or heating them, is not a desireable way to lower your truck. Cutting a coil dimishes the coiling characteristics and eliminates the taper-effect of the top and bottom portion of the coil, where it nests in the pockets of the control arms.
Correct springs or not, it is not recommended to cut coils, however, many do it. Lowering springs are rather economical, so purchasing a new set with the desired drop, is a better route. Not to mention, the original coils have gone through a million spring cycles and may offer a less-than optimum ride. | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | Best way to lower is with spindles. You maintain the correct geometry and suspension travel. Did half ton GMCs have 2 different front springs in 66 ? I am wanting to lower the front. I was told by a friend that has a 66 Chevy that if I had the correct springs I could cut 1 complete coil off the spring and not affect the ride or steering. I have ridden in this truck and it did ride great. I had no idea they were cut. Thanks n Advance
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
