1 members (Steelonsteel), 75 guests, and 1 robot.
Topics128,050
Posts1,055,760
#652157 06/04/2010 2:11 AM
Did half ton GMCs have 2 different front springs in 66 ?
I am wanting to lower the front. I was told by a friend that has a 66 Chevy that if I had the correct springs I could cut 1 complete coil off the spring and not affect the ride or steering. I have ridden in this truck and it did ride great. I had no idea they were cut.
Thanks n Advance
Cutting springs or heating them, is not a desireable way to lower your truck. Cutting a coil dimishes the coiling characteristics and eliminates the taper-effect of the top and bottom portion of the coil, where it nests in the pockets of the control arms.
Correct springs or not, it is not recommended to cut coils, however, many do it. Lowering springs are rather economical, so purchasing a new set with the desired drop, is a better route. Not to mention, the original coils have gone through a million spring cycles and may offer a less-than optimum ride.
NOFORDS #673325 08/26/2010 11:38 PM
Best way to lower is with spindles. You maintain the correct geometry and suspension travel.
Thanks n Advance
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
