Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Phak1, carbking), 107 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#651607 06/02/2010 2:52 AM
1 Offline
I just picked up some 17 inch artillery wheels from a friend that was going to scrap them. Are they worth anything, and what years pickup did they come on?
101053 #651704 06/02/2010 2:23 PM
They are not worth a dime....unless you want to sell them. grin
Builder #651721 06/02/2010 3:14 PM
They are 17 inch and narrow and most of them have six lug holes. You see them used but the right tires are expensive and not very desirable on a driver.
If I had a set of these old wheels they would probably be mounted on the wall of my shop, possibly with a clock in one and speakers in the others.
Several companies repo artillery wheels in modern sizes with tubeless profiles and a choice of lug patterns. They are not expensive as custom wheels go and give very close to the same look.
OldSub #651850 06/02/2010 10:33 PM
1 Offline
Thanks for the reply.
Last edited by cletis; 06/03/2010 3:22 AM. Reason: deleted reference to parts for sale
101053 #651856 06/02/2010 11:25 PM
LOL! Just because that's what I'd do doesn't mean someone out doesn't want them for a correct restoration of the earlier car or truck they came on. You might offer them in the swap meet and make someone very happy.
OldSub #652167 06/04/2010 2:30 AM
Bummer about the artillery wheels! I just bought a '40 GMC 3/4 ton pickup to restore and I got a full set of 18 inch x 6.00/ 6.50 artillery wheels with the truck. I bought a full set of hubcaps for them and they look cool. Eventually I'll need some tires to go on those bad boys. I was wondering if any modern sizes fit? Can you run tubes in tubeless radials? I might cut and widen the back rims to give it more stance. I did price out some repro tires but at $175 apiece that's over my budget. Any ideas?
I'd investigate replacing the hoops with modern tubeless tire hoops. I don't know what size might fit, but widening these wheels would not solve the issues about being tube type and have the tube type rim profile.
You might want to talk to one of the shops that make custom wheels. WheelSmith is the name that comes to mind but there are others.
OldSub #652734 06/06/2010 1:09 PM
Thank you for the info about the artillery wheels. I have to do a restoration on the truck first but will be looking for some 18 x 6.00/ 6.50 tires in the future.
I work as a machinist so I have access to equipment to cut the rims and make hoops to weld in. That's a long ways down the road but it's still something to think about.
