0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#651498 06/01/2010 7:46 PM
Hi getting ready to install my 55 chevy car rear end in my 59 now my queston is why do the drums have to be from the tri-five wouldn't just about any rear drum from a mid size chevy work since they are dependant on the lugs to attach? i know there are some difference but couldn't those be take up with matching brake pads? anyone that knows something on that let me know lol in brain picking mode smile
1937 1/2 ton
You would need to use drums with the same specifications (width and diameter) as the brakes you're running. Later model drums for wider brakes would require not only the proper shoes, but also the backing plate and perhaps even a wider axle shaft.
Bill Burmeister
LONGBOX55 #651508 06/01/2010 8:06 PM
Spend some time in a parts book. I bet you'll find the same drums were used on a lot of GM cars.
OldSub #651556 06/01/2010 11:31 PM
Chevy cars were the only ones that used the 4 3/4 bolt pattern
in that era. However, the rear drums should be the same up through 64 on full size cars. Chevelle's, GTO's and other "A" body cars had the same bolt pattern but used 10" brakes.
Fred
