7 members (52Carl, Wayne67vert, 53 green 1- ton, Otto Skorzeny, 78buckshot, DadsFirstPickup, greenie-reddy),
67
Mod | | | Forums66 Topics128,130 Posts1,056,713 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 56 | When I took apart my grill there was a yellowish (faded) plastic pieces between glass lens and running light housing. Can anyone tell me did this truck come with colored running lights and where can I get the colored plastic piece?
Thank you! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Bruce, What would be the running lights? The head lights? Presumably, you are referring to the front parklamps, which, I think, would have had clear lenses. Parklamps were used to indicate that you were parked (and were not to be used when running/driving). That is why the front parklamps turn off when you pull the light-switch full-out (and the headlamps come on). Here are amber lenses. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Amber lenses were not used in any '50s vehicle. I personally think they look goofy with them. But it's your truck. | | | | | Joined: Aug 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 56 | Yes front parking lamps is what I have and they are clear. I'll just put back together with the clear lense. Someone at some time had put these plastic yellow things behind lens for looks I guess. Thanks for input! | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | I use mine for turn signals, but if the cops ever give me grief about the color I'll probably just find some yellow bulbs for them.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | That's what I did too. I installed a 1157 bulb holder and used yellow bulbs for park/turn lights | | |
