| | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | Hi getting ready to install my 55 chevy car rear end in my 59 now my queston is why do the drums have to be from the tri-five wouldn't just about any rear drum from a mid size chevy work since they are dependant on the lugs to attach? i know there are some difference but couldn't those be take up with matching brake pads? anyone that knows something on that let me know lol in brain picking mode
1937 1/2 ton
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You would need to use drums with the same specifications (width and diameter) as the brakes you're running. Later model drums for wider brakes would require not only the proper shoes, but also the backing plate and perhaps even a wider axle shaft.
Bill Burmeister | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Spend some time in a parts book. I bet you'll find the same drums were used on a lot of GM cars.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Chevy cars were the only ones that used the 4 3/4 bolt pattern in that era. However, the rear drums should be the same up through 64 on full size cars. Chevelle's, GTO's and other "A" body cars had the same bolt pattern but used 10" brakes. Fred
