| | | Forums66 Topics128,078 Posts1,056,054 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 12 New Guy | | New Guy Joined: Jan 2010 Posts: 12 | Hello can anyone tell me what the correct interior color is for my 65 Chevy C10, or does anyone know the color codes? Thank You... | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Here is what we have been using to do our '60-'66 Chevy truck restorations:
Med. Fawn 60% gloss DuPont 9171-L, Ditzler DL-22571, Rinshed-Mason 65B84 Dark Fawn Zero Gloss Du Pont 9202-L, Ditz. DIA 22568 Light Fawn? 60% Du Pont 9170-L Ditz. DL22569 ------------------------------------------------------------------------------------------------------------------------------ Medium Saddle 60% Du Pont 4626-L Ditz. DL-22570 Rinshed-Mason 65B83 Dark Saddle Zero Gloss Du Pont 9199-L Ditz. DIA-13010 The Saddles are from '65, all Fawns are same '65 and '66.
They have worked well for our projects, so maybe they will help someone else out, as well. | | | | | Joined: Jan 2010 Posts: 12 New Guy | | New Guy Joined: Jan 2010 Posts: 12 | Thank you Tony. I will check out these colors. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | My automotive paint supplier is mixing them for me, so my painter can do some spray-outs. I will have a better idea, once I see the spray-out samples. | | | | | Joined: Jan 2010 Posts: 12 New Guy | | New Guy Joined: Jan 2010 Posts: 12 | Hello, thanks for the help. I found a color called Metallic Beige. Have you heard it called this color before? Thank you. | | |
