6 members (Cletus1950, Charles in CA, TrknGMC, UtahYork, dt235sd, Peggy M), 185 guests, and 4 robots.
Topics128,107
Posts1,056,221
Members48,436
Hello can anyone tell me what the correct interior color is for my 65 Chevy C10, or does anyone know the color codes? Thank You...
Here is what we have been using to do our '60-'66 Chevy truck restorations:
Med. Fawn 60% gloss DuPont 9171-L, Ditzler DL-22571, Rinshed-Mason 65B84
Dark Fawn Zero Gloss Du Pont 9202-L, Ditz. DIA 22568
Light Fawn? 60% Du Pont 9170-L Ditz. DL22569
Medium Saddle 60% Du Pont 4626-L Ditz. DL-22570 Rinshed-Mason 65B83
Dark Saddle Zero Gloss Du Pont 9199-L Ditz. DIA-13010
The Saddles are from '65, all Fawns are same '65 and '66.
They have worked well for our projects, so maybe they will help someone else out, as well.
Thank you Tony. I will check out these colors.
My automotive paint supplier is mixing them for me, so my painter can do some spray-outs. I will have a better idea, once I see the spray-out samples.
Hello, thanks for the help. I found a color called Metallic Beige. Have you heard it called this color before? Thank you.
