5 members (3800GUY, Peggy M, Hotrod Lincoln, Shardean, Otto Skorzeny), 75 guests, and 5 robots.
Topics128,021
Posts1,055,349
Members48,420
#651074 05/31/2010 4:57 AM
do all the hoods on 47 thru 53 chevy pickups have the same measurements? i have a 53 and the hood is wider overall than the opening. all the measurements on the fenders and grill are ok. the doors match up fine with the fenders. anybody had this type of problems with their hoods? any help would be apreciated.
blkhrn #651086 05/31/2010 5:35 AM
The hoods should all be the same. Could the hood have been "sat on"? So the sides have spread? Mine has a beveled lower edge, mating to beveled inner edges of the fenders. If the fenders are mounted a little too close together, I can see the hood not dropping in properly. How much too wide is the hood?
Highflyer #651102 05/31/2010 7:06 AM
1-1/2 ton and 2-ton trucks have a different hood. Could you have a big truck hood?
OldSub #651110 05/31/2010 8:03 AM
AFAIK The cab width is the same at the cowl as the lighter trucks.....blkhrn's problem seems to be the width rather than the length difference on the heavier trucks.
I tend to agree with Highflyer,sounds like the hood's splayed.
More pix on Flickr.
jockbolter50 #651137 05/31/2010 3:26 PM
Get out your tape. The big truck hood and fenders are wider even though the cab is identical.
OldSub #651198 05/31/2010 7:09 PM
Steve(OldSub)...I would get a tape out,but trying to find a 'Big Bolt' over here would be the problem!
I assume by wider hood you mean at the front nose, I was aware the fenders are bigger both in width and wheel opening.
That, I could understand,but if the cabs are identical,why would the hood be wider at the cowl?
blkhrn states that on his, everything else seems to fit OK....
More pix on Flickr.
jockbolter50 #651208 05/31/2010 8:11 PM
The way I understand his post the hood is wider overall than the opening. What he says fits fine is the fenders and grill and I took that to mean they fit the truck just fine.
If I've misunderstood him it sure would not be the first time I was confused...
But again, there are several varieties of hoods, and some of the big truck hoods, like for a 3-ton GMC, are huge. I would imagine he is dealing with a Chevy hood which won't be that extreme, but it is larger than the 1-ton and smaller trucks.
