| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 36 New Guy | | New Guy Joined: Dec 2005 Posts: 36 | do all the hoods on 47 thru 53 chevy pickups have the same measurements? i have a 53 and the hood is wider overall than the opening. all the measurements on the fenders and grill are ok. the doors match up fine with the fenders. anybody had this type of problems with their hoods? any help would be apreciated. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | The hoods should all be the same. Could the hood have been "sat on"? So the sides have spread? Mine has a beveled lower edge, mating to beveled inner edges of the fenders. If the fenders are mounted a little too close together, I can see the hood not dropping in properly. How much too wide is the hood?
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | 1-1/2 ton and 2-ton trucks have a different hood. Could you have a big truck hood?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | 1-1/2 ton and 2-ton trucks have a different hood. Could you have a big truck hood? AFAIK The cab width is the same at the cowl as the lighter trucks.....blkhrn's problem seems to be the width rather than the length difference on the heavier trucks. I tend to agree with Highflyer,sounds like the hood's splayed.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Get out your tape. The big truck hood and fenders are wider even though the cab is identical.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Steve(OldSub)...I would get a tape out,but trying to find a 'Big Bolt' over here would be the problem!
I assume by wider hood you mean at the front nose, I was aware the fenders are bigger both in width and wheel opening. That, I could understand,but if the cabs are identical,why would the hood be wider at the cowl? blkhrn states that on his, everything else seems to fit OK....
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The way I understand his post the hood is wider overall than the opening. What he says fits fine is the fenders and grill and I took that to mean they fit the truck just fine.
If I've misunderstood him it sure would not be the first time I was confused...
But again, there are several varieties of hoods, and some of the big truck hoods, like for a 3-ton GMC, are huge. I would imagine he is dealing with a Chevy hood which won't be that extreme, but it is larger than the 1-ton and smaller trucks.
