4 members (Jay R, Chris's 46 / 515, Peggy M, Hotrod Lincoln), 54 guests, and 1 robot.
Topics128,042
Posts1,055,597
#650910 05/30/2010 3:10 PM
Started out as a $20 brake job, one month & $450 later, I've finally have the upgraded to rear discs. Had to change rearends (because I couldn't remove the spider gear pin out of the old one) and shorten the driveshaft and replace all the bearings along the way and removed a leaf to drop it just a bit but over all I think it looks pretty good. The discs are from a 98-02 LS1 & the rearend is an early 70's Camaro.
Robert C.
I'm a Genius in the making.
1950 3600
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Robert remind me never to have you change my brakes..lol
Looks good & I bet it'll stop that bucket of bolts now thumbs_up ...joe
#651055 05/31/2010 3:54 AM
How did your park brake work out?
~Jim
Haven't got a chance to drive it yet. Had trouble starting it and discovered the seal on the tank wasn't seated properly and it was mostly water. Drained it today, will try again with fresh fuel soon.
Robert C.
1950 3600
Haven't got them completely hooked up yet. Gotta mount the hand lever inside & finish running the cables.
Robert C.
1950 3600
