8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
#650892 05/30/2010 1:41 PM
1941 gmc 248 , zenith 28av11 percolates the fuel from the bowl into the throttle area. any tricks to stop this .
I like fixing stuff.
I have heard that you can make a carb spacer out of a hard wood to insulate the carb from the hot intake manifold. I would try a half inch spacer and see what happens. If you are afraid the wood could be a fire hazard (about a thousand to one shot I think) you might try some sheet pcv cut to size. You also might try opening the hood after you stop, to let the heat escape faster. And last I have heard the ethanol mix gas (which runs perfect in my '49 6400) has a slightly lower boiling point.
Do you have an approximately 5/8" thick non-metallic insulator plate between the carburetor and the intake manifold?
Has the carburetor been rebuilt recently - the float level and/or the needle valve/seat might be culprits. One of the carburetor pros will post useful questions and suggestions.
double-posted: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=650890#Post650890
there is a 1/4" thick fiber type deal. where can I get this 5/8 thing. thanks kat
