| | | Forums66 Topics128,052 Posts1,055,719 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | 1941 gmc 248 , zenith 28av11 percolates the fuel from the bowl into the throttle area. any tricks to stop this .
I like fixing stuff.
| | | | | Joined: Apr 2006 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 48 | I have heard that you can make a carb spacer out of a hard wood to insulate the carb from the hot intake manifold. I would try a half inch spacer and see what happens. If you are afraid the wood could be a fire hazard (about a thousand to one shot I think) you might try some sheet pcv cut to size. You also might try opening the hood after you stop, to let the heat escape faster. And last I have heard the ethanol mix gas (which runs perfect in my '49 6400) has a slightly lower boiling point. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have an approximately 5/8" thick non-metallic insulator plate between the carburetor and the intake manifold? Has the carburetor been rebuilt recently - the float level and/or the needle valve/seat might be culprits. One of the carburetor pros will post useful questions and suggestions. double-posted: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=650890#Post650890
| | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | there is a 1/4" thick fiber type deal. where can I get this 5/8 thing. thanks kat
