2 members (Hotrod Lincoln, latroca52), 73 guests, and 5 robots.
Topics128,024
Posts1,055,395
Members48,422
Just got the truck back from paint shop, and changed the color, so in addition I wanted to add a mirror to the right side door.
The left door had pre-drilled holes for mounting the mirror, but, the right door has no holes for mounting.
I had ordered both mirrors/arms (matching) from a dealer, and both sets came with the three mounting screws.
My question is, HOW is the right mirror arm mounted? Is there an insert to put in after drilling the three holes, to screw the screws into? Do you drill the holes and then put nuts on the inside? I thought I would ask here before I continued further. Thanks in advance for your comments.
Take the inside door panel off and you will see the mount support and where to drill. I use nilock nuts on the inside.
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
Mr. Giant-
Thanks, and a beautiful '53 you have there also!
