1 members (Jimmie D),
110
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 10 New Guy | | New Guy Joined: May 2010 Posts: 10 | Hi all. Kinda new to the forum so bare with me. I want to lower the front of my 1962 GMC truck just a bit. I read that you can crank down the torsion bars on an older post. What does that mean and how do you do it? How much lowering can you gain? | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | Actually what you do is unwind or release tension on the bars by loosening the adjusting bolt. Follow the bar to it's rear anchor point, and you'll find it connected to a crossmember under the cab via adjustable arms (as shown below): [IMG]http://img168.imageshack.us/img168/2033/tbaradjust001.jpg[/IMG]Simply unscrew the adjusting bolts and the front will drop. Use caution however in how much you lower the front. The further it drops, the more the arms hang down at the rear. On severely lowered trucks the arms hang below the scrub line and become a road hazard. | | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | My '66 Dart has front torsion bar suspension which allowed me to level out the ride by increasing the tension, followed up with a front end allignment.
Figuring on doing the same on my '62 C-10. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Sniper,
If you decide to fool with them, take this advice, use and let soak a good pentrating fliud, suck as Kroll Oil or PB Blaster. put on a good amount, let soak overnight, apply it again, let soak over night once more, then SLOWLY turn the Big Nut BOTH ways for a little bit. Because if you break the special nut or strip that bolt you're in for a real treat to replace. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something else to keep in mind, when you crank the bars down, you will be decreasing the spring rate, while this may make the ride softer, it will also decrease the springs ability to carry a load. This could end up giving you poor handling characteristics, potential for bottoming out easily (especially with that big heavy V6 up there) and increased tire wear. I would estimate you could probably go 2 inches of drop before you see any issues. You'll also need to get it realigned, as any ride hight change will change camber, caster, and toe. Also be aware, most alignment shops will not guarantee alignments of vehicles with altered suspensions.
Bill Burmeister | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I forgot to add that when I got the truck from the PO he had tried to make a low rider out of it, what he did was lower the front bu 4"+ and put clamps on the back springs (ruined them) When I had the entire front end rebuilt, they actually took a picture from a cell phone showing the differance. ALSO when you lower the front it you may have problems when you are turning and hit a hole it casues the tire to smack into the fender usually denting or bending it as I had on mine. | | | | | Joined: Nov 2003 Posts: 4 New Guy | | New Guy Joined: Nov 2003 Posts: 4 | Should this lowering be done while the truck is on the ground or up on a lift? | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | Theoretically they should be done on the ground so you can see how far the truck drops for a specific turn of the bolts. Practically speaking, doing the adjustment when the suspension is "unloaded" is much less likely to strip the adjuster bolts. If you have access to a lift, you could unwind one turn, drop the truck, raise it back up and do another turn, etc until you're happy with the drop. The same thing could be done with a floor jack and stands, but it would be a lot more work. | | | | | Joined: May 2010 Posts: 10 New Guy | | New Guy Joined: May 2010 Posts: 10 | Everything went perfect. Got a good 2" drop. Bolts were easy to turn when truck was on a jack. (PB Blaster) Still have an inch or so of threads left to adjust if I should want to go any lower. Thanks everyone for helping. | | | | | Joined: Nov 2003 Posts: 4 New Guy | | New Guy Joined: Nov 2003 Posts: 4 | Everything went well for me too on my '62 C-10 Pickup. Between changing the tire height from 33" to 26" and cranking down the front suspension, I was able to lower the overall truck 7" and then the front end an additional 4 inches. I still want to lower the rear end some more and get wider tires. Love this Website...thanks all for your advice. | | |
