2 members (John Dlugos, 1 invisible), 150 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#650042 05/27/2010 4:39 AM
I was wondering if anyone can recommend ideas on how to rebuild the Z Bar on a 65 C10 Chevy? The Z Bar is pretty sloppy and the clutch rods are pretty worn. Does anyone know of a repair kit or does anybody re make the clutch linkage rods? Thank You...
t douds #650124 05/27/2010 3:07 PM
just bore the holes out to take an insert of the right size ,weld it in and grind it flush-like new. you can build up the wear in the rod ends
ron
you can also bore(drill) it out to take the door pin bronze bushings . trim excess and epoxy in
padresag #650145 05/27/2010 4:07 PM
Good information. Quality used parts are readily available, so let me know if I can help. Enjoy the holiday weekend.
