7 members (Otto Skorzeny, Tom McGrath, Gdads51, TPR57C, 32Fordpuchoptop, Wickedbass, 1 invisible),
97
Mod | | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 12 New Guy | | New Guy Joined: Jan 2010 Posts: 12 | I was wondering if anyone can recommend ideas on how to rebuild the Z Bar on a 65 C10 Chevy? The Z Bar is pretty sloppy and the clutch rods are pretty worn. Does anyone know of a repair kit or does anybody re make the clutch linkage rods? Thank You... | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | just bore the holes out to take an insert of the right size ,weld it in and grind it flush-like new. you can build up the wear in the rod ends ron you can also bore(drill) it out to take the door pin bronze bushings . trim excess and epoxy in
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Good information. Quality used parts are readily available, so let me know if I can help. Enjoy the holiday weekend. | | |
