2 members (Guitplayer, MickeyP), 70 guests, and 2 robots.
Topics128,021
Posts1,055,356
Members48,420
#649016 05/23/2010 10:19 PM
I'm thinking about putting power steering on my 46 Chevy using a Toyota box. Will a pump from a mid 80's Chevy work? I have a dual groove pump on hand that would be a snap to build brackets for it and a alternator.
ttodd #649033 05/23/2010 11:11 PM
The only real concern is the pressure out put. i blew the seals on three racks last summer before i got a pressure reducer that worked.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
As Ron stated pressure is an issue. The factory GM pump puts out about 1300psi and the Toyota (and Mustang II rack) operate on about 900psi. I have done both and the best way that I have found to regulate the pressure is by adding shims (small washers) to the pump control valve. The kits are available through speed shops or aftermarket suppliers. The last kit I bought was made by Bill's Hot Rod Parts in So Cal.
Fred
As rfs56 said, easiest /cheapest way to reduce pressure is with a shim kit. Most Hot Rod parts places will carry it.
1940 Chevy KC 1/2-Ton
I used a shim kit also, works great and an easy install. But the thing I found is to shop around. My local speed shop wanted 35.00, found the exact same one from a catalog vender for 14.00
