| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I'm thinking about putting power steering on my 46 Chevy using a Toyota box. Will a pump from a mid 80's Chevy work? I have a dual groove pump on hand that would be a snap to build brackets for it and a alternator. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The only real concern is the pressure out put. i blew the seals on three racks last summer before i got a pressure reducer that worked.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | As Ron stated pressure is an issue. The factory GM pump puts out about 1300psi and the Toyota (and Mustang II rack) operate on about 900psi. I have done both and the best way that I have found to regulate the pressure is by adding shims (small washers) to the pump control valve. The kits are available through speed shops or aftermarket suppliers. The last kit I bought was made by Bill's Hot Rod Parts in So Cal. Fred
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | As rfs56 said, easiest /cheapest way to reduce pressure is with a shim kit. Most Hot Rod parts places will carry it. | | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | I used a shim kit also, works great and an easy install. But the thing I found is to shop around. My local speed shop wanted 35.00, found the exact same one from a catalog vender for 14.00 | | |
