2 members (ChevyBlue, Otto Skorzeny), 224 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
Well, every now and then, the blind pig DOES find the acorn!
A couple months ago, I did a post on here looking for a copy of the original template to locate the spot light brackets, and someone on here hooked me up with a copy of the template.
Two weeks later, I lucked into a deal and ended up with a very nice driver's side spotlight and brackets--inner and outer brackets.
I got it mounted on my '62 Suburban, and started looking around on ebay for the passenger side of brackets. (When you buy vintage spot lights, you're really buying the brackets).
Found a guy on ebay, who knew a guy, and this week a set of very rare, OE passenger-side spot light brackets showed up. So now I'll have a set of factory spots on the Suburban.
And while all this was happening, a good friend of mine called and said "I've got a set of NOS west coast mirrors that I bought for my '65 Chevy truck back in '65, but never put them on. You can have 'em."
They're stainless construction, and are the definition of "mint" condition.
Both of these additions will look good on the truck, and even better, they'll make the truck more functional.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
Good for you, those brackets are indeed rare. Post some pics when you have a chance.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
In case you haven't seen them, the following links may prove helpful when it comes to the install or repairs:
http://67-72chevytrucks.com/vboard/showthread.php?t=401449&highlight=spotlight
http://67-72chevytrucks.com/vboard/showthread.php?t=403869&highlight=spotlight
Nice links Mark! Those would have been at least a little helpful.
The guy in the first link seems to have had a problem with his template. I guess I got lucky--the one a member sent to me was spot-on and perfect.
I ran into that same "extra" piece of metal during the drilling process.
My biggest challenge was figuring out how to take apart the spot light to slide it through the hole.
Now I'm looking for an S6 spot light with a black handle. I haven't checked to see if Unity still sells them with the short black plastic handle.
-Brad
Details here!
Unity does not carry the short handle, it will have to come from an original spotlight sold by GM. It appears all GM spotlights had the same short handle whether for a Chevy truck or a Buick. There was also a short Ivory handle that supposedly came with GMC spotlights.
Be sure to check for the correct overall length. The Unity "A" length I have mounted in a 141L bracket is 14 1/4" overall from the forward end of the headpost housing to the back of the switch cap. Unity measures differently, (center to center) from the center of headpost to center of handle. The "A" length center to center is 12". Some early spec sheets list the "K" length instead, which is 1/2" longer at 12 1/2" c-c.
Thanks for the tip. I'll probably start hunting the second light next month.
The light I have now is a GMC, and it had a black handle. There's no reason to think this isn't the original handle. The guy I bought it from let this one go because he found an NOS GMC light, to replace the very nice light he sold me.
-Brad
Details here!
