0 members (), 90 guests, and 1 robot.
Topics128,055
Posts1,055,782
#649415 05/25/2010 2:33 AM
trying to find a place to order a chrome dipsick and tube for a 235. can anyone help, thank you
No one makes a chrome dip stick for these engines because through the years the length of the sticks have changed due to car use vs. truck use and the length of the tube the stick goes into.
The only way I ever got a chrome stick was to have it chromed. I might mention that there is a problem with a chrome stick. When the oil is new in the engine, it is difficult to see the level of the oil on the chrome stick. I had to paint the lower portion so I could get a "read" on the stick.
You might consider a chrome dip stick handle which can be attached to a regular dip stick.
Another trick for "reading" a shiny dipstick is to drill a small hole at each level line. I find that it makes it much easier to see when the oil is new.
SimS
SimS #649620 05/25/2010 8:05 PM
Good idea, SimS!
I actually finally painted the lower part of mine with a light coat of flat black paint. It is much easier to see the oil against that paint.
Better than paint, torch it til it turns color. I would be nervous about introducing paint to the inside of my engine.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
As luck would have it, I just ran into the same problem and solution. In trying to get the dipstick tube off of the block for a rebuild, I ended up mangling the tube to the point where I could not re-use it. I drove over to a nearby Autozone with the existing tube in hand and found that the accessory chrome dipstick and tube fits in the block. I cut them both down to factory lengths and marked the fill lines with a chisel. Presto, chrome dipstick and tube.
