| | | Forums66 Topics128,087 Posts1,056,107 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64950 08/28/2006 1:55 PM | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Hi All, I have asked this question before but my application has changed. I have a 54 panel with a 350, auto trans, and a mustang ll front end with manual rack & pinion. Can some one tell me what headers I can use to clear the steering linkage? I am using the original column but obviously without the original steering box. Thank you.
All the best, Ted
#64951 08/30/2006 1:21 AM | Joined: Jul 2005 Posts: 3 Junior Member | | Junior Member Joined: Jul 2005 Posts: 3 | No guarantee but I have a similar setup in my 49 and used Block Hugger Headers from Summit Racing. Might not be the best around but I would guess that most block hugger type headers would work. I just could not spend the bucks for Sandersons LD 49 AD 3600 | | |
#64952 08/30/2006 3:35 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Ted, I think this was discussed some time ago and I for one had ask the same question. I believe block huggers will work but someone here suggested trying a set off a 265 or 283 engine. Perhaps even a later model set that the exhaust comes out the back of the header will work?? I am going to have the same problem...when I get to it because I'm putting a 305 in my 52 panel and want to use the same steering box etc... | | |
