1 members (Phak1),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 22 New Guy | | New Guy Joined: Jan 2010 Posts: 22 | I have a steering column out of my 1940 1/2 ton panel I thought was original.Needing to put new bushings in,the parts breakdown from Chevs of the 40's shows 2 bushings on the pitman.Mine only has 1 and it was not even near the end of the shaft.The last 2 in of the box nearer the pitman arm is not even machined for a bushing.It had a metal shim there.I can tell Somebody has been in the steering box before.Here are the # on the steering box Saginaw Gear 263587.Im probably going to have someone machine a bushing for it.Also the pitman arm was only haif on the splines, is this correct?Thanks for any help. | | | | | Joined: Jan 2000 Posts: 21 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 21 | Hi Tim: I see this post is quite old, but I am curious if and how you solved your problem. My '38 half ton has the same gear box and I have it at the machine shop now with the same puzzle you had. I found a NOS pitman arm kit that had two bushings and the split bushing. Near as I can tell from a note in the Master Parts Catalog, there was a problem with chattering and the new kit solves the problem in this particular 37-40 box. Cheers, Mark
One who knows that enough is enough will always have enough. Lao Tzu
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | The OP has not been on the site in over 3 years. Hopefully someone else can answer your question.
