0 members (), 89 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#64926 08/28/2006 3:02 AM
Theirs a 1970 chevelle 4 door that a friend of mine bought for parts and its got a running 250 inline 6 with what looks like a th350 trans attached to it. Would this motor/tranny combo be an easy install for a temp replacement in my 54 GMC 1st series?
At a later date i may rebuild the original motor/trans to drop back in..
Tony
old iron vs. new plastic....no brainer!
TECH WANTED: on S-10 frame swap
PARTS WANTED: 54 Visor, weather strips..
PARTS FOR SALE: I have complete frame / complete driveline from 54 1/2ton. very solid, will seperate
1954 GMC 3100
#64927 08/28/2006 5:07 AM
Tony,
I have done a little reserch on this.I am planning on putting a 1978 250 out of a nova along with the rear end from the nova and hookem together with a T-5 tranny B T W it is a 53 3100.
I have herd you can use the V-8 crossmember avalible at most venders for the side mount sixes,but Langdons Stovebolt sells a moter mount kit just for this conversion-this is what I plan on using -it looks like a neat clean setup.If you plan on useing O.E.gages the capilary tube for the temp gage is to short-Jim Carter sells one with a longer tube intended for V-8s but should work on 250 as well.You will also need a mount for the tranny-vendors sell a generic crossemember mount or you could fabricate.good luck. Aaron
#64928 08/28/2006 6:26 AM
TEMP replacement? why temp i just finished putting this setup on my brother in laws 54 chevy truck, who wants to shift gears if you dont have to. i am using a original hydomatic shifter. when the hood closed no one will know its been updated. all chevy straight 6s sound the same 216, 235 and 250s.
1949 SUBURBAN
#64929 08/28/2006 5:14 PM
Isnt this kit for cars only??? "but Langdons Stovebolt sells a moter mount kit just for this conversion-this is what I plan on using -it looks like a neat clean setup" There web site doest say specifally for either one does it???
#64930 08/30/2006 3:52 AM
ttt
1954 GMC 3100
#64931 08/31/2006 9:51 PM
I called Langdons to check up on this,but they are out until 9/4.I belive the 250 mount kit will work in cars as well as pickups as the frames on cars and pickups in these years are very similar in the engine area.This kit is more than likely to work for many different aplications as long as the frame rails are not to far apart and there are no components in the way(steering box) Aaron
#64932 09/01/2006 1:10 PM
This is a post on a 250 in panel, pretty much what I'm doing (250 in a 51 suburb). So I followed what they said & I have sent in for the weld up/in kit from Steve already, since I already had the ford eng rubber mounts laying around...any hew for what's it worth. I'll post back as progress continues. Thanks...
found out langdons make a mount but it is for 49-54 car. i know the folks at buffalo enterprises and they are a+ folks. you were right about weld in mounts but i would prefer bolt in which is easy to switch in case we want to put in different powerplant.thanks for the response.
here is where to go to read the whole post.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=23;t=000389
#64933 09/01/2006 5:05 PM
Just got off the phone with Chassis Engineering they said they don't make a kit for this,but do sell the individual components-Frame mount kit part #AS-106 19.95 PR, motor mounts part #CS-1419 33.10 each and universal cushin kit part # SS-0011 24.15 PR.I think I will get my motor mounting here.They have a great website with lots of useful products to update the old trucks.Check out the master cylender upgrade
Aaron
#64934 09/08/2006 4:57 AM
thanks aaron, but i decided to go with the m II ifs...easiest and probably the best.
1954 GMC 3100
