3 members (Tronman, PullG, 1 invisible),
141
Mod | | | Forums66 Topics128,288 Posts1,058,578 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64919 08/28/2006 2:14 AM | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | Does a 235 Inline 6 have hydraulic lifters? I have a heck of a chatter on a '55 2nd series I just bought. I'm wondering if I just have to adjust the rockers or if there are hydraulic lifters to clean out. | | |
#64920 08/28/2006 2:29 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If it's the original engine, it will have solid lifters. You cannot install hydraulics in this block, the hydraulic lifter block has a different oiling system. The correct clearance spec for this engine is intake .006", exhaust .016", both set hot. Don't worry too much about the lifters once you set them, Chevies are supposed to be noisy.
Bill Burmeister | | |
#64921 08/28/2006 3:36 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | apbmalibu.
If you are referring to an original truck engine, all truck 216/235/261 engines had mechanical (solid) lifters.
Many (maybe all?) automobile 235 and all Canadian Pontiac 261 engines had hydraulic lifters.
Some later truck 235 and 261 blocks might have been able to use either mechanical and solid lifters but they still came from the factory with mechanical lifters.
Tim | | |
#64922 08/28/2006 4:14 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Mid '56 was when the blocks were all set up for hydraulic lifters.
#64923 08/28/2006 12:00 PM | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | | | |
#64924 08/28/2006 3:38 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1958 was the first year that all blocks were drilled. Before that it was only car engines that were to have Power Glide transmissions that were drilled.
See the USA in your vintage Chevrolet! My Blog | | |
#64925 08/28/2006 5:04 PM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Block casting 3837004 was 1955 2nd series - 1957 truck with mech. cam.
1955-1957 passenger, hyd. or mech. cam also used the 3837004 block.
-Tom
1950 Chevy 3100 w/ 1956 235
