Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (51sub), 187 guests, and 7 robots.
Topics128,288
Posts1,058,578
Members48,492
#64919 08/28/2006 2:14 AM
Does a 235 Inline 6 have hydraulic lifters? I have a heck of a chatter on a '55 2nd series I just bought. I'm wondering if I just have to adjust the rockers or if there are hydraulic lifters to clean out.
#64920 08/28/2006 2:29 AM
If it's the original engine, it will have solid lifters. You cannot install hydraulics in this block, the hydraulic lifter block has a different oiling system. The correct clearance spec for this engine is intake .006", exhaust .016", both set hot. Don't worry too much about the lifters once you set them, Chevies are supposed to be noisy.
Bill Burmeister
#64921 08/28/2006 3:36 AM
apbmalibu.
If you are referring to an original truck engine, all truck 216/235/261 engines had mechanical (solid) lifters.
Many (maybe all?) automobile 235 and all Canadian Pontiac 261 engines had hydraulic lifters.
Some later truck 235 and 261 blocks might have been able to use either mechanical and solid lifters but they still came from the factory with mechanical lifters.
Tim
#64922 08/28/2006 4:14 AM
Mid '56 was when the blocks were all set up for hydraulic lifters.
Bill Burmeister
#64923 08/28/2006 12:00 PM
Thanks guys!
#64924 08/28/2006 3:38 PM
1958 was the first year that all blocks were drilled. Before that it was only car engines that were to have Power Glide transmissions that were drilled.
My Blog
#64925 08/28/2006 5:04 PM
Block casting 3837004 was 1955 2nd series - 1957 truck with mech. cam.
1955-1957 passenger, hyd. or mech. cam also used the 3837004 block.
-Tom
1950 Chevy 3100 w/ 1956 235
