1 members (Cosmo),
84
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | I am getting ready to do the brakes in my resto mod 1939 1/2 ton. Has anyone put a brake booster in with the stock pedal set up?
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod 1937 1 1/2 ton Is in the driveway
| | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | Not in a '39 I know, but I have connected the original master cylinder in my 50 truck to a remote booster mounted on the truck's bulkhead.
I have a CPP disc conversion on the front axle and drums at the rear. The brake setup works really well; I haven't needed to install any proportioning or residual pressure valves.
The booster I used was the model for an Austin Healey 3000 or Jaguar Mk 2; you'd probably find an American made unit is cheaper and easier to get hold of though.
Stuart. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | If you can stand the thought of running riceburner parts, there are several small-diameter boosters on Jap imports that can be shoehorned into the frame rail area near where the original M/C mounts, and operated with an offset pushrod. I'd suggest adapting a master cylinder to the booster that's more volume-compatible with whatever brake system you're planning to run, as the Jap rigs run some very small-diameter M/C's. It would take a little fabrication work, but it's doable with a little tinkering. Jerry
| | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | I am going to run 4 wheel disc brakes. I am fabricating my master cylinder mount on my original setup like one of the bolters did...I'd have to look up his name. I am going to run a dual master with 1" bore.
| | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | Brians40 is the member that I am following to do my fab work. I'm new to this stuff... I know what an offset is... But how would it work to the booster
