6 members (Southerntruck, 1955 1 Series, cmayna, Otto Skorzeny, Hanks custodian, wilbur53), 89 guests, and 0 robots.
Topics128,156
Posts1,056,870
Members48,456
#649155 05/24/2010 7:22 AM
Here's some recent pictures of my truck. It's pretty much done other than I need an emergency brake and I need to figure out how to hook a speedo cable from a t-5 transmission to my guage.
http://s864.photobucket.com/home/millermd/recentuploads?view=slideshow
ch3no2 #649158 05/24/2010 7:55 AM
I absolutely love your truck. Great job. The stance is perfect
"Effective leadership is putting first things first. Effective management is discipline, carrying it out."
---Casey---
http://s676.photobucket.com/albums/vv127/davisears/?albumview=slideshow
REAL_RAT_FINK #649159 05/24/2010 8:03 AM
Thanks. It's got a mustang II clip from Fat man under it with a full coil taken out. In the rear I had some offset blocks made to move the rearend so the wheel/tire would be centered in the wheel well....it took a lot of time to get it right in addition to the tire/wheel combination.
ch3no2 #649173 05/24/2010 12:35 PM
Leo Offline
Moderator
Moderator
Welcome, you're right in saying it takes a lot of time to get it right. You did a greta job.
Leo
Leo #649317 05/24/2010 8:48 PM
Here's some more details on my truck
Wiring – EZ Wiring
Rear End – 8” Ford 2.70 Gears Front End – Fat Man Ford Mustang II IFS (1 coil removed)
Brakes – Front Disc, Rear Drum
Engine – 1958 Chevrolet 235 .030
Camshaft – Howards
Lifters – Solid
Pistons – Venolia
Ingnition – Mallory Electronic
Coil – Mallory
Exhaust – Custom Dual Exhaust with Smithy’s
Headers – Fenton Headers …Jet Hot Coated
Duel Carburetors – Dual Carter Weber w/elect. Chokes
Air Cleaner – finned from Obrien Truckers
Manifold – Offenhauser...Dual intake manifold - with custom Phenolic plates
Wheels – 15” Solids with Rings & Caps
Tires – Coker Classic 6.7-15 front, L78-15 Rear
Oil Filter – Remote finned Moon
Valve Cover & Side Cover - Offenhauser
Transmission – S-10 -5 speed
Fuel & Oil Lines – Russell
Moderated by  J Lucas
