| | | Forums66 Topics128,163 Posts1,056,918 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 13 New Guy | | New Guy Joined: May 2010 Posts: 13 | Here's some recent pictures of my truck. It's pretty much done other than I need an emergency brake and I need to figure out how to hook a speedo cable from a t-5 transmission to my guage. http://s864.photobucket.com/home/millermd/recentuploads?view=slideshow
| | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | I absolutely love your truck. Great job. The stance is perfect | | | | | Joined: May 2010 Posts: 13 New Guy | | New Guy Joined: May 2010 Posts: 13 | Thanks. It's got a mustang II clip from Fat man under it with a full coil taken out. In the rear I had some offset blocks made to move the rearend so the wheel/tire would be centered in the wheel well....it took a lot of time to get it right in addition to the tire/wheel combination. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome, you're right in saying it takes a lot of time to get it right. You did a greta job.
Leo | | | | | Joined: May 2010 Posts: 13 New Guy | | New Guy Joined: May 2010 Posts: 13 | Here's some more details on my truck
Wiring – EZ Wiring Rear End – 8” Ford 2.70 Gears Front End – Fat Man Ford Mustang II IFS (1 coil removed) Brakes – Front Disc, Rear Drum Engine – 1958 Chevrolet 235 .030 Camshaft – Howards Lifters – Solid Pistons – Venolia Ingnition – Mallory Electronic Coil – Mallory Exhaust – Custom Dual Exhaust with Smithy’s Headers – Fenton Headers …Jet Hot Coated Duel Carburetors – Dual Carter Weber w/elect. Chokes Air Cleaner – finned from Obrien Truckers Manifold – Offenhauser...Dual intake manifold - with custom Phenolic plates Wheels – 15” Solids with Rings & Caps Tires – Coker Classic 6.7-15 front, L78-15 Rear Oil Filter – Remote finned Moon Valve Cover & Side Cover - Offenhauser Transmission – S-10 -5 speed Fuel & Oil Lines – Russell
