2 members (Peggy M, crenwelge), 173 guests, and 3 robots.
Topics128,077
Posts1,056,015
Members48,433
#648815 05/23/2010 12:31 AM
I am new to this so please bear with me until i am up to speed. I finally purchased a 1952 gmc panel. i have had my eye on it for two years but the price was too high for me. then the owner came down into my range and i jumped. it is a model 9435 with dual tanks and a 292 engine. it came with new rubber and three tranys one 5 speed installed and 2 ,4 speeds in the back. along with axles and brake pads and the pile of parts i ave not yet identified. does anyone have info on how to get a build sheet from a vin number.
Since you have a Canadian model number I assume you have a Canadian serial number too. If you post the number one of the Canadian members can probably interpret it for you. I don't think there is a way to get a build sheet to go with it.
The 292 is not the original motor and that 5-speed isn't original either.
I'm not up on Canadian model numbers. Is it a 1/2-ton or a 1-ton?
OldSub #648849 05/23/2010 3:19 AM
Welcome to the bolt archiemark. Looks like patience paid off for you. Your in for lots of challenges and lots of fun.
OldSub #648858 05/23/2010 3:44 AM
thank you. the serial number is 2943504183.
i know that the old fellow who had the truck did a lot of changes so that it is not stock. but he put a lot of care into every change that he made. any help with the serial is appreciated.
Is that serial # coming from the metal tag,with all the weight specs,etc., on the lower driver side hinge pillar or the smaller stainless tag just above the larger one ? I think it makes a difference when trying to get info.
the metal tag had the following information:
model 9435
vin 2943504183
engine xc542474
trim 394
paint 230
body serial 112
there was a lower tag but i did not read it is this any help to you to help me. thanks
in advance the first pic is @http://s859.photobucket.com/albums/ab157/archiepilot/1952%2()gmc%2()model%2()9435 i think. very far awat but the close up show the rust.
archiemark #648905 05/23/2010 11:05 AM
Here is some information on the numbers for Canadian trucks:
Canadian Serial Numbers
Your panel is a 1 Ton. I am unable to get your link to work but would really like to see your photos.
Welcome to the Stovebolt.
1951 1 Ton Completed
truckernix #649069 05/24/2010 12:52 AM
thank you i will post some new pictures tomorrow after i take some . i have been removing all the extra bits the previous owner liked. roof rack,stove piping ,winch and iron cow catcher. it will look different after the long weekend. s859.photobucket.com/albums/ab157/archiepilot/1952%20gmc%20model%209435/
