1 members (klhansen), 92 guests, and 1 robot.
Topics128,049
Posts1,055,741
Can someone please tell me where the thermostate is on Apache is it near the black hose on the bottom of radiator?
1959 CHevy Apache
What engine is this on? On my 235 it is located on the driver's side, read part of the head.
58' 3200 235 3-speed/OD
Youll have better luck if you follow the top hose to where it meets the engine.
Thanks guys I will check the top hose tank you.
1959 CHevy Apache
there is a metal housing 'gooseneck' on the front of the engine that the top rad hose hooks to, the thermostat is under that housing, 2 bolts to open
Thanks squeeze man!
1959 CHevy Apache
Guys why do i always get overflow when i take the thermostat housing off. Car is not hot or anything. IN other words its not like i had driven it hours prior and i loosen the radiator cap. Is there something that I ma missing please help. IM getting radiator flusid all on the engine and i wuld hate it to go into the oil
1959 CHevy Apache
The thermostat housing sits lower than the top of the radiator. Before you take it off, you need to partially drain the radiator, at least to where the coolant level is below that housing.
Or am I misunderstanding your question?
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Unless I am missing somthing,your thermostat is lower than the fluid level in the radiator isn't it? Why are you removing the
thermostat housing so often??
yes its does sit lower and i get it now smile I removed the housing to change toa 160 thermo but the housng was caked in so after i took off it began to leak through a hair line fraqcture on housing. I just took it off i hope y leak stops.
1959 CHevy Apache
